BMW E36 POWAŻNY PROBLEM Z HAMULCAMI RĘCZNYM???POMÓŻCIE
WITAM
MAM PROBLEM Z HAMULCAMI W BMW E36 1,8 SILNIK M40 NIE JEST TO SAMO CO BMW E30 JAK TO BYŁO PODANE W FOTORELACJI WYMIANY SZCZĘK NA FORUM MIANOWICIE,JAK KUPIŁEM AUTO TO PO CZASIE TEN HAMULEC NIE BYŁ ZA SPECJALNY,W AUCIE ZNALAZLEM JAKIEŚ ODPOWITRZNIKI NOWE BS NIE DZIAŁAŁ PRZY KUPNIE,CHYBA COS JUZ BYLO ROBIONE,ALE NIE W TYM RZECZ,PRZYSZEDŁ CZAS NA WYMIANE KLOCKÓW I SZCZĘK ZACZĘŁY TRZEC,
WYMIENIŁEM,KLOCKI,SZCZĘKI,BĘBNY,LINKI RĘCZNEGO HAMULCA(ZESTAW NAPRAWCZY) JEDEN CYLINDEREK,AUTO POSIADA ABS ALE NIE DZIAŁA NA KOMPUTERZE KOLES POWIEDZIAŁ ZE JAKIS ELEKTRO ZAWÓR MOŻE PADL?
POJAWIŁ SIE PROBLEM PO PRZEKRĘCENIU STACYJKI PEDAŁ WPADA TROCHĘ W PODŁOGE,JEST MIĘKKI I JAK NACISKAM TO COŚ SYCZY,SAMOCHÓD PRZY HAMOWANIU NIE STAJE DĘBA,JAKĄŚ CHWILE JEDZIE I RZUCA GO,NA POWIERZCNI PIASZCZYSTEJ,ZAUWAZYŁEM TYLKO DWA LADY HAMOWANIA,CHYBA POWINNY BYĆ 4 ŚLADY KOŁA?
TERAZ RĘCZNY HAMULEC NIE DZIAŁA ,ZNACZY DZIAŁA LAPIE JAKGDYBY PRZY SAMYM KONCU,LINKA PODCIAGNIETA DO SAMEGO KONCA,LINKI SA NOWE!
Z TYŁU PRZY BĘBNIE PRZY SAMOREGULATORZE JEST TAKA BLASZKA NA SPREZYNIE I Z JEDNEJ STRONY SPADA PO NACISNIECIU PEDAŁU,?
CO TO MOZE BYC WYMIENIŁEM REZCY NA NOWE I LIPA
TERAZ MOJE PYTANIE:
-DLACZEGO RĘCZNY LAPIE TAK SLABO?
-CZY UKŁAD NADAL ZAPOWIETRZONY I DLATEGO NIEPRAWIDLOWO HAMUJE BADZ WOGOLE NIE HAMUJE TYŁ I NIE DZIAŁA RĘCZNY,CZY RĘCZNY MA COŚ WSPÓLNEGO Z ZAPOWIETRZONYM UKŁADEM
-CO Z TĄ BLASZKĄ NA SPREZYNCE PRZY SAMOREGULATORZE DLACEGO SPADA?
-PRZY ZAKŁADANIU NOWYCH SCZĘK SAMOREGULATOR POWINIEN BYĆ WKRĘCONY DO KOŃCA CZY ROZKRĘCONY,NADMIENEI ZE JAKO ROZKRECILE MTO NIE MOGŁEM ZAŁOŻYĆ BĘBNA?
-CO TO ZA SYCZENIE PRZY WCISKANIU PEDAŁU HAMULCA?CZY TAK MA BYĆ?
BARDZO PROSZĘ O POMOC SNIEGI NADCHODZĄ,PATRZYŁEM NA FORUM O WYMIANIE SZCZ[fade:00ec51d488]K BĘBNÓW I KLOCKÓW ALE PODANE JEST FOTORELACJA ALE OD E-30 A TO JEST ZUPEŁNIE INACZEJ NIZ W E36 1,8
MOGŁBYM PROSI EWENTUALNIE JAKIES FOTKI
PROSZE WAS O POMOC[/b][/fade:00ec51d488]
