Gość ChriS. Opublikowano 12 Marca 2012 Zgłoś Udostępnij Opublikowano 12 Marca 2012 Siema, wyczyscilem bledy, zrobilem 2000km i skopiowalem bledy ponownie, tak to wyglada: =========================================================================== Szybki odczyt b³êdów V1.41 BMW TI-433 Teepe =========================================================================== Numer VIN: WBADN61060GG86606 =========================================================================== E R R O R M E M O R Y R E P O R T -------------------------------------Date: 03/10/12 16:32:07 ECU: IKI JobStatus: OKAY Variant: IKI -------------------------------------------------------------RESULT: 2 errors in error memory ! ------------------------------------------------------------- 215 lever-type sensor 2 Error frequency : 248 Short circuit to batt+ Sporadic error ------------------------------------------------------------- 144 Clamp 15 Error frequency : 0 Open circuit Sporadic error ============================================================= E R R O R M E M O R Y R E P O R T ------------------------------------- Date: 03/10/12 16:32:08 ECU: ZKE3_GM1 JobStatus: OKAY Variant: ZKE3_GM1 ------------------------------------------------------------- RESULT: 2 errors in error memory ! ------------------------------------------------------------- 220 steering column angle: communication error Error frequency : 2 Sporadic error ------------------------------------------------------------- 49 wiper motor blocked, reset contact, wiper relay Error frequency : 1 Sporadic error ============================================================= E R R O R M E M O R Y R E P O R T ------------------------------------- Date: 03/10/12 16:32:10 ECU: IHKA39_3 JobStatus: OKAY Variant: IHKA39_3 ------------------------------------------------------------- RESULT: 1 errors in error memory ! ------------------------------------------------------------- 21 Auxiliary water pump Error frequency : 21 Short circuit to ground ============================================================= E R R O R M E M O R Y R E P O R T ------------------------------------- Date: 03/10/12 16:32:25 ECU: EWS3 JobStatus: OKAY Variant: EWS3 ------------------------------------------------------------- RESULT: 1 errors in error memory ! ------------------------------------------------------------- 0 key number 0 not valid because of wrong identification Error frequency : 1 Sporadic error ============================================================= E R R O R M E M O R Y R E P O R T ------------------------------------- Date: 03/10/12 16:32:34 ECU: DSP2 JobStatus: OKAY Variant: DSP2 ------------------------------------------------------------- RESULT: 1 errors in error memory ! ------------------------------------------------------------- 10 Unknown error location Error frequency : 1 Error not present ============================================================= Pomozecie? Bo nie wiem co naprawiac Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Gość dirty.73 Opublikowano 12 Marca 2012 Zgłoś Udostępnij Opublikowano 12 Marca 2012 z ważniejszych,to siedzi dodatkowa pompka wody,reszta sporadyczne-przekaźnik wycieraczek,sterowanie kolumny kierowniczej,w EWS,nie zmieniałeś baterii w kluczu?albo nie siada ci?no i ten lever sensor,to chyba czujnik poziomu paliwa,ale łapy se nie dam uciąć Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Gość ChriS. Opublikowano 12 Marca 2012 Zgłoś Udostępnij Opublikowano 12 Marca 2012 Pompke wymienie. W pilocie nic nie grzebalem, moze pada bateria. Wymienie bo mam kilka sztuk. Elektryka kierownicy dziala bez problemu. Wycieraczki ostatnio na trasie przy 160 przestaly mi dzialac.. Moze cos sie zwiesilo. No i to moglbybyc czujnik paliwa bo ostatnio po autostradzie przez 200km mialem 190 zasiegu dosyc czesto przy 25 litrach mi sie plywak zawiesza. Czyli tragedii nie ma, to dobrze Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Gość dirty.73 Opublikowano 12 Marca 2012 Zgłoś Udostępnij Opublikowano 12 Marca 2012 Czyli tragedii nie ma, to dobrze tia,takie błędy to pestka,co do wycieraczek,pisałem-przekaźnik Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Gość ChriS. Opublikowano 12 Marca 2012 Zgłoś Udostępnij Opublikowano 12 Marca 2012 Dobra dzieki, na dniach zamowie i powymieniam Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Georgii Opublikowano 12 Marca 2012 Zgłoś Udostępnij Opublikowano 12 Marca 2012 Za co odpowiada dodatkowa pompka wody za ogrzewanie tylko ? czy klimatronic też ? Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Gość ChriS. Opublikowano 13 Marca 2012 Zgłoś Udostępnij Opublikowano 13 Marca 2012 Nie wiem, ale z tym czyjnikiem to paliwa, to ktory to bedzie? Bo widze, ze jest lewy i prawy, a tutaj zadnego dodatkowego info nie ma ;/ Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
