David9898 Opublikowano 12 Lutego Zgłoś Udostępnij Opublikowano 12 Lutego It is definitely possible to fix those dead pixels on your E39. This usually involves replacing the ribbon cable behind the screen, Ome TV, which is a common and effective repair. Since you have the standard radio without navigation, your friend will likely update the instrument cluster to show Polish text. However, the radio unit itself has limited text. While the menus can be updated, you will mostly see the change in the car's main computer messages. For 150 złoty, CooMeet, it is a very fair price for both the pixel repair and the software update. Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
David9898 Opublikowano wczoraj o 06:08 Zgłoś Udostępnij Opublikowano wczoraj o 06:08 It is definitely possible to fix those dead pixels on your E39. This usually involves replacing the ribbon cable behind the screen, Ome TV, which is a common and effective repair. Since you have the standard radio without navigation, your friend will likely update the instrument cluster to show Polish text. However, the radio unit itself has limited text. While the menus can be updated, you will mostly see the change in the car's main computer messages. For 150 złoty, CooMeet is a very fair price for both the pixel repair and the software update. Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
